Gadget dashboard filter across projects
Firas Abdallah
Hi all,
I noted that in Activity Stream gadget (dashboard) we can see all the activities across JSM projects. I'm asking if it is possible to elaborate a report based on more than one JSM project? and if there are more gadgets that display results across projects?
Kristján Geir Mathiesen
December 6, 2022
Hi @Firas Abdallah
Usually there is a saved filter behind gadgets. First step is to create a saved filter (which can be across projects) and then choose the filter in the gadgets configuration.
You can read about manage filters  And also here.
The Activity Stream supports saved filters:
HTH,
KGM
Firas Abdallah
Thank you very much
STANDARD Trial
