Sign up Log in
Get Insight attribute with Scriptrunner Behavior
Jan Scherks November 25, 2020
I'm trying to get value from Insight Object Attribute (High, Medium, Low) and use that value in IF statement.
Following code is working in Script console:
def customFieldManager = ComponentAccessor.customFieldManager
def customField = customFieldManager.getCustomFieldObject("customfield_27522")
def customFieldValue = issue.getCustomFieldValue(customField)
def myObjectBean = customFieldValue[0]
log.info objectFacade.loadObjectAttributeBean(myObjectBean.getId(), 217).getObjectAttributeValueBeans()[0].getValue()
 But when adapt it to Behavior it's just not working at all:
def affectedComponents = getFieldById("customfield_27522") //Affected Component
def af_val = affectedComponents.getValue()
def affCompObjectBean = af_val[0].getId()
def affCompoValue = objectFacade.loadObjectAttributeBean(affCompObjectBean, 217).getObjectAttributeValueBeans()[0].getValue()
I'm getting Static type checking errors in both. But Console runs fine and gets me attribute value.
Did anyone manage to get Insight atributes working in Behaviors?
Jan
Martin Bayer _MoroSystems_ s_r_o__
November 26, 2020
Hi @Jan Scherks I suggest you to start using loggin mechanism.
Static type checking errors does not mean the behaviour script is not executed successfully.
But when you are working with field "on the screen" I guess that for example for
getFieldById("customfield_27522").getValue()
you won't get the same type of the value as in first script, so I would really log everything first:
log.error "Affected components:" + affectedComponents
log.error "Affected components value:" + af_val
log.error "Aff bean:" + affCompObjectBean
log.error "Aff component bean value:" + affCompoValue
Then check your server log file (atlassian-jira.log) and post the output here and we can proceed with this information...
Jan Scherks November 26, 2020
Hi @Martin Bayer _MoroSystems_ s_r_o__
here's my log:
020-11-26 11:50:17,795+0000 http-nio-8080-exec-19 url:/rest/scriptrun.../runvalidator.json username:jscherks ERROR jscherks 710x146919x1 1i911eq 81.109.22.22,172.35.2.115 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] *************************************************************************************
2020-11-26 11:50:17,797+0000 http-nio-8080-exec-19 url:/rest/scriptrun.../runvalidator.json username:jscherks ERROR jscherks 710x146919x1 1i911eq 81.109.22.22,172.35.2.115 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: (create issue) project/issuetype: MRTP/Release, user: jscherks, fieldId: customfield_27525, file: <inline script>
groovy.lang.MissingMethodException: No signature of method: java.lang.String.getId() is applicable for argument types: () values: []
Possible solutions: getAt(groovy.lang.IntRange), getAt(java.lang.String), getAt(int), getAt(groovy.lang.IntRange), getAt(groovy.lang.Range), getAt(groovy.lang.EmptyRange)
 at 970a9376984666c6ec6e8f5d8273db59.run(970a9376984666c6ec6e8f5d8273db59.groovy:30)
 at com.onresolve.jira.behaviours.BehaviourManagerImpl$_runValidator_closure2.doCall(BehaviourManagerImpl.groovy:194)
 at com.onresolve.jira.behaviours.BehaviourManagerImpl.runValidator(BehaviourManagerImpl.groovy:141)
 at com.onresolve.jira.behaviours.BehaviourManagerImpl.runValidator(BehaviourManagerImpl.groovy:91)
 at com.onresolve.jira.behaviours.restservice.BehavioursEndpoint$_runValidator_closure3.doCall(BehavioursEndpoint.groovy:137)
 at com.onresolve.jira.behaviours.restservice.BehavioursEndpoint$_runValidator_closure3.doCall(BehavioursEndpoint.groovy)
 at com.sun.proxy.$Proxy4316.get(Unknown Source)
 at com.onresolve.jira.behaviours.restservice.BehavioursEndpoint.withServletThreadLocal(BehavioursEndpoint.groovy:222)
 at com.onresolve.jira.behaviours.restservice.BehavioursEndpoint.runValidator(BehavioursEndpoint.groovy:131)
 ... 19 filtered
 at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:159)
 ... 1 filtered
 at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:69)
 ... 32 filtered
 at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:55)
 ... 8 filtered
 at com.atlassian.jira.plugin.mobile.web.filter.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:59)
 ... 4 filtered
 at com.atlassian.jira.plugin.mobile.login.MobileLoginSuccessFilter.doFilter(MobileLoginSuccessFilter.java:54)
 ... 3 filtered
 at com.atlassian.diagnostics.internal.platform.monitor.http.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:55)
 ... 8 filtered
 at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
 ... 46 filtered
 at com.atlassian.ratelimiting.internal.filter.RateLimitFilter.doFilter(RateLimitFilter.java:73)
 ... 3 filtered
 at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.runWithChangedThreadName(AbstractThreadFilter.java:69)
 at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.doFilter(AbstractThreadFilter.java:53)
 at com.atlassian.ams.shipit.servlet.filter.AbstractThreadFilter.doFilter(AbstractThreadFilter.java:37)
 ... 14 filtered
 at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
 ... 1 filtered
 at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
 ... 16 filtered
 at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
 ... 19 filtered
 at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
 ... 5 filtered
 at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:212)
 at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:136)
 at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:89)
 at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
 at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:203)
 at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:134)
 at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:123)
 ... 9 filtered
 at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:37)
 ... 3 filtered
 at com.atlassian.ratelimiting.internal.filter.RateLimitPreAuthFilter.doFilter(RateLimitPreAuthFilter.java:71)
 ... 3 filtered
 ... 4 filtered
 ... 3 filtered
 at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
 ... 26 filtered
 at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
 ... 24 filtered
 at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
2020-11-26 11:50:17,799+0000 http-nio-8080-exec-19 url:/rest/scriptrun.../runvalidator.json username:jscherks DEBUG jscherks 710x146919x1 1i911eq 81.109.22.22,172.35.2.115 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] Returning map: [:]
 Regards
Jan
November 26, 2020
hi @Jan Scherks I think I will need the complete configuration of behaviours and screen maybe... it is weird that not even the first log record is present in the log file.
Here's the Behavior config:
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectFacade
import com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectTypeAttributeFacade
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
@WithPlugin("com.riadalabs.jira.plugins.insight")
def subst = getFieldById("customfield_26720") //Substantial Change Area/Case
def messageText = """
<div>
<span class="aui-icon aui-icon-small aui-iconfont-error aui-icon-notification"></span>
Selected Affected Component has high criticality for Spain. You will have to answer below, an additional question to identify whether it is a Substantial Change or not.
</div>
/* Get Insight Object Facade from plugin accessor */
ObjectFacade objectFacade = ComponentAccessor.getOSGiComponentInstanceOfType(ObjectFacade)
ObjectTypeAttributeFacade objectTypeAttributeFacade = ComponentAccessor.getOSGiComponentInstanceOfType(ObjectTypeAttributeFacade)
def objectTypeAttributeBean = objectTypeAttributeFacade.loadObjectTypeAttributeBean(217)
def field = getFieldById(getFieldChanged())
def marketsVal = field.getValue()
//def affCompObjectBean = af_val[0].getId()
//def affCompoValue = objectFacade.loadObjectAttributeBean(affCompObjectBean, 217).getObjectAttributeValueBeans()[0].getValue()
if ((marketsVal==~/.*RC-94.*/ || marketsVal==~/.*RC-92.*/) && (af_val ==~ /RC-1/ || af_val =~ /RC-5/ || af_val =~ /RC-10/ || af_val =~ /RC-12/ || af_val =~ /RC-15/ || af_val =~ /RC-16/ || af_val =~ /RC-17/ || af_val =~ /RC-19/ || af_val =~ /RC-20/ || af_val =~ /RC-22/ || af_val =~ /RC-26/|| af_val =~ /RC-186/ )){
//if ((marketsVal==~/.*RC-94.*/ || marketsVal==~/.*RC-92.*/) && affCompoValue == "High"){
subst.setHidden(false)
subst.setRequired(true)
field.setHelpText(messageText)
} else {
subst.setHidden(true)
subst.setRequired(false)
subst.setFormValue(["",""])
field.setHelpText("")
Out of many I have following fields:
Affected components (Insight field) - customfield_27522
Market (Insight field) - where the Server side script is - field changed
When the script is just checking Insight object IDs (RC-26/RC-22/...) from the field value it's working but that approach is not suitable for large number of components with High Criticality.
So Market has to be either Spain (RC-94) or All Markets (RC-92) and one of the High Critical components (RC-26/RC-22/...)
November 26, 2020
hi @Jan Scherks  thank you for the detailed information. First I would simplify script to debug it, try to use this one and post the log file here again :)
log.error "Subst:" + subst
log.error "object facade:" + objectFacade
log.error "object type attribute facade:" + objectTypeAttributeFacade
log.error "object type attribute bean:" + objectTypeAttributeBean
log.error "field:" + field
log.error "marketsVal:" + marketsVal
log.error "Affected component bean:" + affCompObjectBean
Jan Scherks November 27, 2020
Hi @Martin Bayer _MoroSystems_ s_r_o__ ,
thanks for the script.
Unfortunately it's failing on the following line:
same error as with my script:
Anyway I was playing with different way how to check the Criticality and found the way this morning :)
import com.atlassian.jira.component.ComponentAccessorimport com.onresolve.scriptrunner.runner.customisers.PluginModuleimport com.onresolve.scriptrunner.runner.customisers.WithPluginimport com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectFacadeimport com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectTypeAttributeFacadeimport com.riadalabs.jira.plugins.insight.channel.external.api.facade.IQLFacade
@PluginModule IQLFacade iqlFacade
def messageText = """<div>    <span class="aui-icon aui-icon-small aui-iconfont-error aui-icon-notification"></span>    Selected Affected Component has high criticality for Spain. You will have to answer below, an additional question to identify whether it is a Substantial Change or not.</div>"""
def value = 0
def afString = af_val.toString()
def highCriticality = iqlFacade.findObjectsByIQLAndSchema(1, "\"Spain Criticality\" IN (\"High\")")
if (afString.contains(",")) {
    highCriticality.each { object ->
    af_val.each { cf ->
    def string = object.toString()
     if (string.contains(cf.toString())) {value = 1}
}} else {
        if (string.contains(af_val.toString())) {value = 1}
if (!af_val) {value = 0}
if ((marketsVal==~/.*RC-94.*/ || marketsVal==~/.*RC-92.*/) && value == 1 {
} else {
Basically I'm searching for objects with IQL = "Spain Criticality" IN "High". Then iterate with value/s from Affected components field through the IQL results and storing the result into a variable. Because the value from Affected components field can have multiple value I have to check if it's single/multiple and iterate accordingly.
It will need a bit more polishing before releasing into Prod JIRA :)
Thank again for the help (Diky za pomoc ;) )
Regards
Jan
November 28, 2020
OK @Jan Scherks so I guess it is working now... instead of "value" variable which is Integer, I suggest you to use boolean variable and true/false... it would be nicer solution :)
No problem ( neni zac :))
Martin
