Get Null values from custom fields that are populated with user ID in scriptrunner
Alex Sprague
When I use the following script that I put together I am getting null values for the ApproversCFval and the and the ApprovalsCFval. It does populate the customfield_10557 with null-null.  the approversCFval should be a user id that i have confirmed is already populated with a user id value.
Is this related to the customfield data type or how the script is written?
Is there a different way to pull a value from a custom field that is a user picker type?
Also the ApprovalsCFval will be pulling from a custom field that has a approvals data type and that is also returning a Null value.
def projectKey = issue.fields.project.key
def issueKey = issue.key
// Get the issue object
def customFields = get("/rest/api/2/field")
.asObject(List)
.body
.findAll { (it as Map).custom } as List<Map>
def approversCFId = customFields.find { it.name == 'Approvers' }?.id
logger.info("${approversCFId}")
def approversCFval = customFields.find { it.name == 'Approvers' }?.val
logger.info("${approversCFval}")
def approvalsCFId = customFields.find { it.name == 'Approvals' }?.id
logger.info("${approvalsCFId}")
def approvalsCFval = customFields.find { it.name == 'Approvals' }?.val
logger.info("${approvalsCFval}")
def PostToField = customFields.find { it.name == 'AActionVAL' }?.val
logger.info("${PostToField}")
def resp = put("/rest/api/2/issue/${issue.key}")
.header('Content-Type', 'application/json')
.body([
fields: [
"customfield_10557": "${approversCFval}" + "-" + "${approvalsCFval}"
.asString()
Anyone have any insight into this?
Thanks in advance
