Get custom field value after creation
Mamikon Papikyan
January 11, 2021 edited
Hi Atlassian,
I want to get custom field value after issue creation. Here is my code where I'm setting value to custom field:
 void set_custom_field_value(String value, String destField, Issue issue)
CustomFieldManager cm = ComponentAccessor.getCustomFieldManager();
CustomField f = cm.getCustomFieldObjectByName(destField);
DefaultIssueChangeHolder ch = new DefaultIssueChangeHolder();
f.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(f),
value), ch);
This works and I can see value in the custom field, but I couldn't get it from Rest API. It gave me null.
This works in jira 7.x perfectly, I can get the custom field value.
Sorry for bad English :).
Mamikon
mogavenasan
January 15, 2021
Hi @Mamikon Papikyan,
REST API endpoint for Jira Server and Jira Cloud is different. Can I know how you are getting the custom field value using REST API?
Moga
FREE
