Get/set Date field value using behavior in jira
Dharnesh February 11, 2021
Hi Experts
Need help.....!
Using behavior script- trying to achieve below
Need to Get value of Custom date field and then need set new value(10 days from the date selected in custom field) in Due Date field.
For example
Custom field Datefield selected as 26/Feb/2021
The in DUE DATE, need to set (10+(datefield Value)). So due date would be 7/Mar/2021
Can please help with logic and script.
Burak Kaya
Hi there,
You may use the script below;
Please do not forget to change the cf ID and username for the operation before use it.
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.Issue;
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.atlassian.core.util.DateUtils
import com.atlassian.jira.security.JiraAuthenticationContext
import java.text.SimpleDateFormat
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
def issueManager = ComponentAccessor.getIssueManager()
def issue = underlyingIssue
MutableIssue mTarget = (MutableIssue) issue
JiraAuthenticationContext authContext = ComponentAccessor.getJiraAuthenticationContext()
authContext.setLoggedInUser(ComponentAccessor.getUserManager().getUserByName("admin")) //type username for change operation
ApplicationUser automationUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def dateFieldCF = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_11998") //type cf id of the date field
def dateFieldValue = issue.getCustomFieldValue(dateFieldCF).toString()
def newDate = new SimpleDateFormat("dd.MM.yyyy").format(dateFieldValue).plus(10)
mTarget.setCustomFieldValue(dateFieldCF, newDate)
issueManager.updateIssue(automationUser, mTarget, EventDispatchOption.DO_NOT_DISPATCH, false)
Best Regards,
Burak
Dharnesh March 1, 2021
Hi @Burak Kaya
don't see in above code trying to set date for DUE Date -> System Field
Below is for example
Custom field ABC (Type - Date Field) selected as 26/Feb/2021
Learn more
