Get user values from Active directory
Szymon Bieńkowski
May 11, 2021
if someone was wondering how do get values from AD with Scriptrunner, f.e. get manager of Reporter, here you have:
1. You must configure connection with your AD in Scriptrunner - tab Resources.
2. Create Custom Field to display value (in my script is "Przełożony" field)
3. Add script in Listeners:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.onresolve.scriptrunner.ldap.LdapUtil
import org.springframework.ldap.core.AttributesMapper
import javax.naming.directory.SearchControls
import javax.naming.directory.Attributes
import com.atlassian.jira.issue.CustomFieldManager
def Reporter = event.issue.reporter?.displayName
def cf_Manager = LdapUtil.withTemplate('Picker from LDAP') { template ->
template.search("", "cn=$Reporter", SearchControls.SUBTREE_SCOPE, { Attributes attributes ->
attributes.get('manager').get()
} as AttributesMapper<String>)
def issue = event.issue as Issue
def cf_Przelozony = customFieldManager.getCustomFieldObjects(event.issue).find {it.name == "Przełożony"}
def changeHolder = new DefaultIssueChangeHolder()
cf_Przelozony.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(cf_Przelozony), cf_Manager.toString()),changeHolder)
Fadi Aljabali
February 10, 2022
Hi Szymon  ,
thanks to post this , what is the custom field type you refer to ?
in addition, playing around your script I tried following in console and working well except it shows byte[] for manager attribute while for string attributes it is working well ,
not sure if that something you experienced before or you may help with ? using Active Directory
import org.apache.log4j.Logger
import org.apache.log4j.Level
import org.springframework.LdapDataEntry
import org.springframework.ldap.core.support.AbstractContextMapper
import org.springframework.ldap.query.LdapQueryBuilder
import org.springframework.ldap.query.SearchScope
import org.springframework.ldap.support.LdapEncoder
import org.springframework.ldap.filter.EqualsFilter
def log = Logger.getLogger("com.abc")
log.setLevel(Level.DEBUG)
final resourcePoolName = 'my ldap'
def managerName = LdapUtil.withTemplate('my ldap') { template ->
template.search("", "(cn=some name)", SearchControls.SUBTREE_SCOPE, { attributes ->
attributes.get("manager").get()
} as AttributesMapper<Object>)
log.debug managerName.toString()
Szymon Bieńkowski
April 26, 2022
Hi Fadi,
unfortunately I have the same :)
Licences AKMF
January 12, 2022
it won't work in console tab - you must put it in listeners
Angelin January 11, 2022
I have configured the LDAP connection but still, when I try running the script in the console, neither did get any results nor any errors.
Licences AKMF
January 11, 2022
Hi Angelin,
script is in Listeners tab, but you must have configured Connection in "Resources" tab to your LDAP host.
Hi Szymon,
The script you have shared is not working for me. Where exactly you have run this script?
