×I am trying to get value from a profields custom field but the code is not working.
Versión:7.7.1
Proveedor:DEISER
Clave de la aplicación:com.deiser.jira.profields
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.deiser.jira.profields.api.field.status.StatusField
import com.deiser.jira.profields.api.field.FieldService
import com.deiser.jira.profields.api.value.ValueService
@WithPlugin("com.deiser.jira.profields")
// Project key
pkey = XXXX
def project = ComponentAccessor.getProjectManager().getProjectByCurrentKeyIgnoreCase(pkey)
def fieldService = ComponentAccessor.getOSGiComponentInstanceOfType(FieldService.class)
Field statusField = (StatusField) fieldService.get(25)
def statusValue = profieldsFieldService.getValue(project, (StatusField) statusField)
The log error is following.
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl@6e5379a' with class 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl' to class 'com.deiser.jira.profields.api.field.status.StatusField' at Script2600$_buildHTMLTableOfIssues_closure1$_closure4$_closure5$_closure7$_closure8.doCall(Script2600.groovy:221) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4$_closure5$_closure7$_closure8.doCall(Script2600.groovy) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4$_closure5$_closure7.doCall(Script2600.groovy:152) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4$_closure5.doCall(Script2600.groovy:151) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4$_closure5.doCall(Script2600.groovy) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4.doCall(Script2600.groovy:138) at Script2600$_buildHTMLTableOfIssues_closure1$_closure4.doCall(Script2600.groovy) at Script2600$_buildHTMLTableOfIssues_closure1.doCall(Script2600.groovy:136) at Script2600$_buildHTMLTableOfIssues_closure1.doCall(Script2600.groovy) at Script2600.buildHTMLTableOfIssues(Script2600.groovy:119) at Script2600$buildHTMLTableOfIssues$0.callStatic(Unknown Source) at Script2600.run(Script2600.groovy:71)
Hi Mauricio, I'm Carlos from DEISER and I'm working in Profields Team.
First of all, are you sure that the field id "25" is the id of a status field? the error you get is probably thrown because of that.
After you check that, you need to change a little bit the script. The value of the field in a project is obtained with the ValueService
The script below should be work:
// Project key
pkey = "XXX"
// Status field id
fieldId = ??
def valueService = ComponentAccessor.getOSGiComponentInstanceOfType(ValueService.class)
def statusField = fieldService.get(fieldId)
def statusValue = valueService.getValue(project, (StatusField) statusField)
If you continue getting errors please, let me know
Regards
Carlos
Hi Carlos.
Thank you for your support.
I continue having problems.
// get profields project field (text custom field)
cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(new Long(11387))
//get project key from jira custom field cascading list
def pkey = ((Map<String, String>) issueObj.getCustomFieldValue(cf)).get(null)
def fieldId = 25
Message log error is:
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.project.CachingProjectManager.getProjectByCurrentKeyIgnoreCase() is applicable for argument types: (com.atlassian.jira.issue.customfields.option.LazyLoadedOption) values: [MTRA] Possible solutions: getProjectByCurrentKeyIgnoreCase(java.lang.String)
After that message chaged
def project = ComponentAccessor.getProjectManager().getProjectByCurrentKeyIgnoreCase(pkey.toString())
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl@6c42a498' with class 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl' to class 'com.deiser.jira.profields.api.field.status.StatusField'
Could you help me please?
Do you check if the field with id "25" is a status field?
Absolutely and I was trying with other id fields. But is not working.
Can you execute this?
fieldService.get(25).class.name + ": " + fieldService.get(25).type
In order to know what kind of field is returned by the field service, because it seems a problem with the field type
Sorry: I edited the answer, because it has errors
Log info:
I had edited the script but you got it before, can you execute the edited script again? I fix errors and change the result line
Is not working this line
pkey is a string value with project Key.
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.project.CachingProjectManager.getProjectByCurrentKeyIgnoreCase() is applicable for argument types: (com.atlassian.jira.issue.customfields.option.LazyLoadedOption) values: [CADR] Possible solutions: getProjectByCurrentKeyIgnoreCase(java.lang.String)
Hi Mauricio
I think you have two different problems:
In the code pasted below I explain each case
Please configure the two IDs of the fields, for the cascading and for the project status field.
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
// Cascading custom field id
def CASCADING_ID = 10000L
// Status field id
def STATUS_FIELD_ID = 100
def projectManager = ComponentAccessor.projectManager
def customFieldManager = ComponentAccessor.customFieldManager
// Get the cascading custom field
def customField = ComponentAccessor.customFieldManager.getCustomFieldObject(CASCADING_ID)
// Get the value of the cascading field
// This field returns a map that has two keys "null" and "1" and the values are LazyLoadedOptions
// To get the String value of a LazyLoadedOption you need to call the getValue() method of the object
// Then you get the values of each drop down like this:
// valuesMap.get(null).value -> first drop
// valuesMap.get(1).value -> second drop
def projectKey = ((Map<String, LazyLoadedOption>)issueObj.getCustomFieldValue(customField)).get(null).value
// Get the project with the previous key
def project = projectManager.getProjectByCurrentKeyIgnoreCase(projectKey)
// Get the Profields project Status field
def statusField = fieldService.get(STATUS_FIELD_ID)
// Get the value of the status field in the project
def statusValue
try{
}catch(def ex){
log.error "Error casting the field: ${ex.message}"
log.error "Field: ${statusField}"
log.error "Class: ${statusField.class.name}"
log.error "Type: ${statusField.type}"
// Return the value
return statusValue?statusValue.text:"none"
Hope it helps
Regards
Carlos
Hi Carlos.
Thanks a lot for your support.
The code has not errors but is not working. :(. I changed profields custom field and the result is same.
Log error is following:
Field: com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl@457fde63
Class: com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl
Type: TEXT
2021-03-12 12:42:07,681 ERROR [runner.ScriptBindingsManager]: Error casting the field: Cannot cast object 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl@62f2722e' with class 'com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl' to class 'com.deiser.jira.profields.api.field.status.StatusField' 2021-03-12 12:42:07,681 ERROR [runner.ScriptBindingsManager]: Field: com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl@62f2722e 2021-03-12 12:42:07,681 ERROR [runner.ScriptBindingsManager]: Class: com.deiser.jira.profields.impl.field.type.generalfield.GeneralFieldImpl 2021-03-12 12:42:07,681 ERROR [runner.ScriptBindingsManager]: Type: TEXT
Hi Mauricio
The id is related a Text field. Where do you get this id? Can you send a screenshot with the field and the type?
Thanks Carlos.
I get id profields custom field from profields field section. Selecting each field are showing ID when you put your mouse pointer over profield field.
I tried to get information about other fields but the result is same.
Hi Mauricio
Depends on the field type, you need to cast to its related field type class in the script
For example, for the field in the screenshot you should do:
// Get the Profields project Text field
def field = fieldService.get(10)
// As the field is a field of type text, you get the value casting to the class TextField
// you will need the import: import com.deiser.jira.profields.api.field.text.TextField
def value = valueService.getValue(project, (TextField) field)
Can you add the screenshot for the field 25 in order to investigate what would be the problem?
Hi Carlos.
Is working now. Thanks a lot for your support.
Regards!
Great!
Don't hesitate to contact us if you have any further questions.
Regards
