Hello all, I am developing a event listener plugin using the example in the docs.
I have a User story which is in a Epic and in my listener whenever the User story is updated i want to perform some action on the story for which i also need the ID of the Epic.
From the UI i can see the Story is linked to Epic (under "Epic Link"), but in the the issue object, i get in the listener i cant seem to be able to see the property, i have seem examples where people have tried to use customfields to get the Epic info. When i debug, i see that the issue has no customfields.
Is there any other way to get the Epic ID from User Story.
Thanks in Advance
I was able to solve my problem by doing the following
// this does not work, returns null
// CustomField field = customFieldManager.getCustomFieldObject("Epic Link");
// i have seen examples of this, but doesnt work
// CustomField field2 = customFieldManager.getCustomFieldObject("customfield_10101");
// What worked was
List<CustomField> fields = customFieldManager.getCustomFieldObjects(issue);
CustomField epicLinkField = null;
for (CustomField field : fields) {
if ("Epic Link".equals(field.getFieldName())) epicLinkField = field;
Issue epicLink = null;
if (epicLinkField != null) {
// we get the Epic issue object
epicLink = (Issue) issue.getCustomFieldValue(epicLinkField);
@integmas - Epic link change doesn't have a webhook you can use.
So changing the epic link in the UI doesn't trigger anything.
You can create a schedule automation to run every X mins/hours/days (depending on what you're trying to get) and copy the epic link to a new custom field (text type). Then, when the value of that custom field changes you'll get a webhook notification to your listener.
Thanks for the reply.
I want to get the Epic name from issue, i have created a EventListener in my plugin using the annotation "@EventListener".
I am able to catch the issue in my listener but i cant see a way to get "Epic" from issue, without running any queries.
