Git and Svn side by side temporarely
Christiaan van Bergen
August 14, 2013
We just moved our code from Svn to Git. Now I would like to configure the rest of our Atlassian products to use Git. I know where to do just that, but I am wondering...will my Jira messages automatically link to both the Svn repositories and the Git repositories? Or will enabling Git mean that Svn will not be accessible anymore?
Another question would be: if my code-movement failed. Can I start over and continue to work with Svn (untill the end-of-service) ? In other words, can I switch back to Svn?
Thx.
Timothy
August 15, 2013
If the Git commit has the issue keys, then there should be no problem.
Of course not. They are separate things.
Depending on how you move your code. Personally, git-svn has never been an issue for me. You should schedule a downtime and a cut off period on your SVN for the migration so that you know that it works and that no more commits will be made to the SVN after the migration.
Register now
