×Hello,
I've configured Jira and GitLab according to this link: GitLab Integration and committed regarding my Issue (It's within the starter scrum test project in which I opened a new issue: SCRMTST-24) using those comments:
SCRMTST-24 #done <comment...>
SCRMTST-24 #close <...>
SCRMTST-24 #close #comment <...>
closes #SCRMTST-24
<Another closes #SCRM... here>
All commits (except for the last mentioned in the <>) are listed in Jira as comment but the ticket itself is still staged as "in progress".
As Transition IDs in GitLab I specified 3; 10000; 10001; 10100; 10101 according to the return value of that rest api call (Transition IDs).
Any ideas why it's not working?
Thanks a lot
Hi @Markus Miller ,
I might not be the best person to answer this question, but this seems to be exactly the same topic discussed in the below GitLab issue:
Can you kindly review above link and let me know if it helps?
Dario
thanks for your reply. I've tried several different transaction ids and none of them worked.
Since I haven't heard anything about the topic in a while I found a diferent solution by using a plugin now.
Thank you
Thanks for your reply @Markus Miller .
Even you you already made it work, you might still want to review the thread I pointed to since in there different causes and solutions are explored.
However, since this is not an issue for you anymore I am marking this question as answered.
Have a nice day!
Dario
Hi, do you resolve the question? I meet the same question, can you help me ? Thanks a lot
Hi @Azusa ,
As written in above reply:
Since I haven't heard anything about the topic in a while I found a different solution by using a plugin now.
Indeed, there is a number of add-ons available for this in our marketplace:
If this is not desired, you may also want to review below links since alternative ways are suggested in there:
I hope this helps.
Dario
You may also want to watch below videos:
