Give rights to adjust comment Visibility
Thomas Gottmann December 11, 2019
Hello Together,
i have a specific project - where i would like to give an internal group the possibilty to share the comments only with their group.
Currently this group also comment with "Viewable by All Users " - as admin im able to share it with specific groups. How and where do i give the rights to this group to be able to also restrict their comments on their own.
Best regards,
Thomas
2 accepted
Don Masten
December 11, 2019
Check under JIRA Settings > System > General Configuration for "Comment visibility" make sure it's set to "Groups & Project Roles" and not "Project Roles only"
https://confluence.atlassian.com/jirakb/add-restricted-comments-on-jira-962353957.html
Thomas Gottmann December 13, 2019
thank you Don, this works for me!
Like Alex Laycy likes this
Alex Laycy
December 11, 2019
Hi Thomas,
Restrictions on the visibility of comments depends on the type of project being used / viewed.
If you're using a JIRA Core / JIRA Software project type then you should see a padlock symbol at the bottom right hand side of the comment field. When you click it, you should then see a list of groups/roles that you can restrict the comment to.
Your administrator can choose to make the options either project roles, or project roles and groups.
Hope this helps!
- Alex
Register Now
