Global Transition which I can bring up a screen for logging work from any State
Ram Muddam August 8, 2016
In JIRA, I have a few plugins installed, including Script runner and JIRA Misc workflow, etc.
I am implementing the plugin, "JIRA Role based Estimations and Tracking". In that plugin, I need to create a screen, which displays the logged work fields. This plugin does not use the regular logged work fields.
I want to be able to call up this screen from any status (except Closed), using a transition, which will bring up the screen and then go back to the same status. But I do not want to be creating this transition individually for each status in the workflow.
Can anyone point me in the right direction?
  • Additional plugins workflow related
  • Groovy scripting for auto transitioning and going back to the previous state
I will be able to use this in many other areas as well.
Thank you in advance.
Steve Behnke [DiscoverEquip.com]
August 8, 2016
You don't need any add-ons, this is possible out of box. This was added sometime after 5.0. The functionality to create these was missing between JIRA 6.3 and JIRA 6.4.4. Something like that.
Edit a workflow. Navigate to the GUI editor. Press +Transition. Select ANY STATUS for the from field and ITSELF for the to field.
Voila, you now have a no-result transition.
Ram Muddam August 10, 2016
Thank you for your prompt response. Saved me a lot of time.
One more question: In this Transition to Self, how can I conditionally not show it, when the issue is in a particular status?
I know you can have a conditional clause, but how do I restrict it to not show for one status.
August 10, 2016
You do need an add-on for that.
The free add-on (avaliable for BOTH Server and Cloud) JSUTIL provides a condition. The Value Field Condition allows you to specify conditions to show or not show an action.
I would add the Value Field Condition with a condition of Status != Your Status
Ram Muddam August 12, 2016
Thank you again for your response and it is exactly what I was looking for.
Steven F Behnke
August 13, 2016
Excellent, no problem. smile
Learn more
