Got problem with the issue view in projects if the Add-on "Threaded Comments" is active
olai-web May 11, 2015
Hi we got a problem with the issue view in projects when the add-on is active.
it's about that Add-on https://marketplace.atlassian.com/plugins/info.renjithv.jira.addons.threadedcomments.threaded-comments#support
If we use the issue overview tab in the project the list is gone and also the .js has some problems. The main navigation is also broken. we need help for that problem it affects all the browsers (chrom, ff, safari, ie11)
Henri Volk
May 13, 2015
HI, same issue here. Will there be a fix soon? Had to disable the plugin.
Renjith Pillai
May 12, 2015
I will look into this Marco.
olai-web May 12, 2015
i'm using version 1.7 on JIRA 6.4.3
Help us plant more trees
