Grant permission to bulk transition issues
Sheri
We are using Jira cloud version. I am set up as an administrator and a site-admin. I need to perform bulk transitions.
On the project permissions page 'Transition Issues' permission has been granted to the Group site-admins, but when I go to the Bulk Operation wizard I see N/A for Transition Issues and 'NOTE: You do not have permission to perform a bulk transition ..'
Please let me know what setting I need to change where so that I can perform bulk transition.
Many thanks,
Sheri
2 accepted
3 votes
Kimberly Deal _Columbus ACE_
July 12, 2018 edited
@Sheri
Bulk Changes are a Global permission. They are found under
Settings
System
Global Permissions
Make bulk Changes.  Make sure you are in one of those groups or use the Add Permission at the bottom of the page to add a group.
Sheri
Thanks! Now that this question has been answered, how do I set it to solved?
You can click on the grey check mark next to an answer to set it as an accepted solution. @Mikael Sandberg's answer solved your issue, so click the check next to his.
Like Andy - PTC Redundant likes this
Mikael Sandberg
Just click the check mark next to the answer and it will mark the question as solved:
https://community.atlassian.com/t5/Feedback-Forum-articles/How-and-why-to-accept-a-solution-to-your-question/ba-p/656156
Sheri
Thanks! It is difficult being a newbie :-)
January 28, 2019
@Kimberly Deal _Columbus ACE_ : More than just AUG Breakfast sessions :oD
Thanks for this knowledge share. It helped a lot !
Burak Oluroğulları September 15, 2021 edited
Dear Kimberly,
I am in administrators group and administrators group have granted to use bulk actions in global permissions. However I can not do bulk actions.
you can see screenshots below;
https://imgur.com/a/S7XxRGf
Thanks in advance,
Burak
Ben Racicot March 13, 2023
Thank you Kimberly! You should be teaching the other mods how to answer questions!
You're quite welcome!  There are many accomplished Mods here and I'm pretty grateful to be in such company.  Thanks for being part of the Community. :)
Mikael Sandberg
Hi Shari,
Welcome to the Atlassian Community.
Check your workflow to see if you have any restrictions on it that only allows a specific user/project role/group to perform the transition.
Sheri
Hi Mikael,
Thank you for the warm welcome, and for your answer. The problem was indeed with our workflow. We have it sorted out now.
Sreenivasaraju P
July 12, 2018
Under Global permissions, you can see Make bulk changes permission. Please check this permission for whom all this have been enabled.
You can check global permissions @ /secure/admin/GlobalPermissions!default.jspa path of your cloud instance
Sheri
Thanks for the suggestion. It turned out the problem was with our workflow restrictions, not with the bulk changes permissions.
@Sheri
Glad you found the solution!
January 28, 2019
This was handy for those of us not experiencing workflow challenge :D
November 4, 2019
January 28, 2019
This is why I LOVE making great use of community... after changing 30 issues manually I "got off my arse" (still sitting down actually, LOLz) and looked up the Bulk Changes on Community.....🤩🥇👍
Check this beauty of a screenshot ! !
Nice!  WTG @Andy - PTC Redundant!
January 28, 2019
Thanks Kimberly!
