Graph with story types counted by velocity
Vasilis Gennaris
April 19, 2018 edited
Hi all,
I am trying to find a gadget or a way to create a filter that will present the story types presenting by velocity points and not by how many pieces are in total. Is there a way?
Benito Picarelli
May 9, 2018
Hi Vasilis,
It looks like a filter gadget configured to display the estimation field along with the issue type might do that. Have you attempted perform this through that set up?
Or, if that's not what you meant by "By not how many pieces are in total", can you give me more information about what you'd like to achieve here?
Benito Picarelli
Vasilis Gennaris
May 10, 2018 edited
Hi Benito,
I just try to have the below pie graph displayed by percentage based on velocity and not based on absolute issues number.
Do you have any gadget to suggest because i can't find one that uses the Estimation field for display..
Thanks in advance!
Vasilis Gennaris
I found out the "Workload Pie Chart" but I am getting an error..
