From what i see on the Greenhopper configuration JIRA page there is no way to customize the cards against different projects. I have 3 projects that need to map their cards to specific column configuration.
Is this possible?
You can customise the card configuration per project via Agile tab > Tools (appear on the top right of the page) > Configurations > Card Styles tab. You can refer to the following documentation as a guideline: http://confluence.atlassian.com/display/GH/Configuring+your+Card+Styles
This configuration would be per issue type rather than project. Any other clues?
