×As per the following Knowledge Base Article:
https://confluence.atlassian.com/display/GHKB/Difference+between+Global+Rank+and+Rank
It explains that "As for the Global Rank field, this is an extra field used on Rapid board."
Hence, is it safe to delete other fields and just make use of the Rank field solely for GreenHopper?
There can be more than one field of type 'Global Rank', each board can specify which one to use in the board filter. Be careful not to delete rank fields that might be used by boards.
Shaun
hi ahmad.
in the 6.0m06 i only see "Rank" as a customfield. i believe this is the only relevant one.
reading the field description of Global Rank makes me think that this one was introduced with GH Labs Rapidboard function. i might be wrong
