The Classic GreenHopper burndown chart StartDate/EndDate could be found using this call :
{JIRA_HOST}/rest/greenhopper/latest/chartdata/generate-hourburndown.json?projectKey={0}&versions={1}&contexts=2.gh.boards.defaultctx&chartType=gh.chart.ahourburndown
It would produce structured data. As part of that data there would be a legend. Each element in the legend would be a day and each had a java timestamp. The first element would be the StartDate and the last would be your EndDate.
Is there a similar Rest call to retrieve the data on the RapidBoard? I've found the following calls useful, but they don't give me the data I'm actually looking for.
//Get a list of rapidview project ids
{JIRA_HOST}/rest/greenhopper/1.0/rapidviews/list
//Get a list of sprints in the project
{JIRA_HOST}/rest/greenhopper/1.0/sprints/{RapidViewID}
Seems like there should be another API call after that one to give me issues in the sprint and sprint details, but if there is I can't seem to find it.
I found a startDate and endDate using the following call:
{JIRA_HOST}/rest/greenhopper/1.0/xboard/work/allData/?rapidViewId={rapidViewId}
the result contains a key called 'sprintsData' you can find startDate nd endDate there
Thank you! This is exactly what I needed. I appreciate your time.
Can someone please help on this command, I'm trying to run by getting page not found.
