×I recently upgraded from 5.0 to 5.2 and am using JDK 1.7. I cannot get Greenhopper 6.0.7 to load and run. It looks like its complaining about neededing something on JDK 1.6. I have this running successful in my test environment, but not in my production environment. I cant find anything that is different. I have cleared all the tmp, work and cached plugin directories and am still encountering this issue.
2012-12-04 16:13:52,877 FelixDispatchQueue ERROR [osgi.container.felix.FelixOsgiContainerManager] Framework error in bundle com.pyxis.greenhopper.jira
org.osgi.framework.BundleException: Unresolved constraint in bundle com.pyxis.greenhopper.jira [116]: Unable to resolve 116.0: missing requirement [116.0] package; (&(package=javax.xml.parsers)(version>=0.0.0.1_006_JavaSE)(version<=0.0.0.1_006_JavaSE))
at org.apache.felix.framework.Felix.resolveBundle(Felix.java:3409)
at org.apache.felix.framework.Felix.loadBundleClass(Felix.java:1584)
at org.apache.felix.framework.BundleImpl.loadClass(BundleImpl.java:887)
at com.atlassian.plugin.osgi.util.BundleClassLoaderAccessor$BundleClassLoader.findClass(BundleClassLoaderAccessor.java:75)
at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
at com.atlassian.jira.plugin.DefaultComponentClassManager.constructEvenIfNotEnabled(DefaultComponentClassManager.java:133)
at com.atlassian.jira.plugin.DefaultComponentClassManager.newInstance(DefaultComponentClassManager.java:70)
at com.atlassian.jira.event.ListenerFactory.getListener(ListenerFactory.java:31)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.loadListeners(DefaultListenerManager.java:162)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.create(DefaultListenerManager.java:104)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.create(DefaultListenerManager.java:99)
at com.atlassian.util.concurrent.ResettableLazyReference$InternalReference.create(ResettableLazyReference.java:143)
at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:326)
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:146)
at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:115)
at com.atlassian.util.concurrent.ResettableLazyReference.get(ResettableLazyReference.java:89)
at com.atlassian.jira.event.DefaultListenerManager$Listeners.start(DefaultListenerManager.java:126)
at com.atlassian.jira.event.DefaultListenerManager.start(DefaultListenerManager.java:47)
at com.atlassian.jira.ComponentManager.runStartable(ComponentManager.java:282)
at com.atlassian.jira.ComponentManager.startJIRA(ComponentManager.java:246)
at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:212)
at com.atlassian.jira.ComponentManager.start(ComponentManager.java:197)
at com.atlassian.jira.upgrade.PluginSystemLauncher.start(PluginSystemLauncher.java:23)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:105)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:169)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:98)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:25)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:64)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:59)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:80)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:75)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:108) <+5> (StandardContext.java:4791) (StandardContext.java:5285) (LifecycleBase.java:150) (ContainerBase.java:1559) (ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
GreenHopper 6.0.7 is simply not compatible with JDK 1.7. Please upgrade to GreenHopper 6.0.8 immediately.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
