Details
Exception: Script error.
Line: 0
Environment
Mozilla/5.0 (Windows NT 6.1; rv:18.0) Gecko/20100101 Firefox/18.0
Hi Kevin,
It seems you are facing a known bug (<tt>GHS-5502</tt>), which happened due to jira.atlassian.com not delivering the correct resource file when requesting. From Renjith's comment in the bug report, a hard refresh should fix this issue (<tt>CTRL/CMD + SHIFT + R</tt>) should fix this issue if you are the only one facing it. Otherwise, please follow the steps described in the KB linked below to remove feedback related errors:
Also, if you don't have the latest version of GH installed (which I suspect you already do, and in this case you can ignore the following) it may be possible that once you disable the feedback module in GreenHopper a new error is presented, that may happen due to another bug in GreenHopper which is now fixed in the latest GreenHopper release (6.1.3.2) - you can see the bug report for this at <tt>GHS-7317</tt>. If this new problem is indeed displayed once you disable the feedback module, please upgrade GH to the latest version in order to avoid it.
I hope this helps!
Matheus Fernandes
Hi Kevin,
It seems that you are running to the same problem describe here: https://answers.atlassian.com/questions/138587/error-report.
