Groovy script to append current user to multi-user picker
Joshua DeClerck
I have an approval-style workflow post-function that appends the current user to a multi-user picker custom field. So far I've used the non-groovy "Update Issue Custom Field" post-function to append "%%CURRENT_USER%%", which doesn't behave reliably for all types of usernames. Since that method has no flexibility, I'd like to switch over to a groovy script.
The behavior ultimately relies on comparing two multi-user picker fields, "Required Approvers" and "Approved by". An "Approve" transition has been set up expecting two conditions and two post-functions:
  1. Condition - the current user is listed in "Required Approvers".
  2. Condition - the current user is not listed in "Approved by".
  3. Post-function - append the current user to "Approved by".
  4. Post-function - ScriptRunner fast-track transition to the next phase of the workflow if the following condition is met:
    cfValues['Approved by'] as Set == cfValues['Required Approvers'] as Set
The comparison in (4) breaks down because certain usernames (mixed case) aren't stored by "Update Issue Custom Field" (3) the same way they're stored when manually entered into the "Required Approvers" field.
In trying to re-do (3) with ScriptRunner, I'm struggling to find any up-to-date examples of appending currentUser to this type of field. The closest I've found has ultimately boiled down to using an operation like this:
Approvers.updateValue(null, issue, new ModifiedValue("", user), changeHolder);
(based on code found here)
However, the ModifiedValue() part doesn't seem to be valid code anymore in the latest versions of JIRA+SR. Or at least, every example of it that I've been able to find throughout the community now returns errors.
Is there a newer, more recommended way to do this?
Thanks in advance for any help!
3 votes
Vasiliy Zverev
October 19, 2016
Here is code example to do this:
CustomField multiUser = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("fieldName")
List<ApplicationUser> users = issue.getCustomFieldValue(multiUser)
users.add(ComponentAccessor.getUserManager().getUserByName("username"))
issue.setCustomFieldValue(multiUser, users);
Joshua DeClerck
Thanks @Vasiliy Zverev! Starting from this, I was able to end up with something that seems to be working the way I hoped. I ran into a type checking error on line 7, but appending "as List" cleared it. The only other problem was that add() fails when users is null, but that was a simple fix, too. All in all, very happy -- thank you!
Bridgestone
February 25, 2017
This code doesn't work if the multiuser picker field "fieldname" doesn't contain anything. I'm getting this error:
ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: null, actionId: 1, file: <inline script>
java.lang.NullPointerException: Cannot invoke method add() on null object
Any idea? Thanks!
Vasiliy Zverev
February 26, 2017
Lets try this one
List&lt;ApplicationUser&gt; users = issue.getCustomFieldValue(multiUser)
if(users == null)
    users = new ArrayList&lt;&gt;();
Manjunatha K R
Hi Vasiliy,
Thanks for sharing this scripts, works well for us to copy a Jira issue Reporter name into multi user customfield value. In multi user, we are not appending the value as it's having one name only as of now.
def componentCF2 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("ITG To Test")
String selectedComponents2 = issue.getCustomFieldValue(componentCF2)
def componentCF1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Defect Source")
String selectedComponents1 = issue.getCustomFieldValue(componentCF1)
if(selectedComponents1 == "Design Server" && selectedComponents2 == "NO")
String reporter = issue.reporter?.name
issue.setAssigneeId(reporter)
String reporter1 = issue.reporter?.name
CustomField multiUser = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Test Managers")
List<ApplicationUser> users;
//= (List<ApplicationUser>) issue.getCustomFieldValue(multiUser)
if(users == null)
    users = new ArrayList<>();
users.add(ComponentAccessor.getUserManager().getUserByName(reporter1))
Manjunatha K R
Same postfunction working script doen's work in when we use in Fast-track transition - not sure why?
ScriptRunner workflow function - Fast-track transition an issue (condition & additional actions apply
- Manju
Manjunatha K R
Thanks for sharing the above script Vasiliy Zverev,
I customized your script to copy/overwrite Reporter of the Jira issue to other multi user picker custom field i,e Test Managers value in my post function, it working as expected for our usage.
if(users == null)
Alibek Malikov February 28, 2019
if(users == null)
!!!I use this script in the post-function but it gives an error!!!
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script23.groovy: 9: unexpected token: ; @ line 9, column 28. users = new ArrayListlt;&gt;(); ^ 1 error </pre>.
 What have I done wrong?
Vasiliy Zverev
March 3, 2019
if(users == null)
    users = new ArrayList();
Try this one
Like • Alibek likes this
Joshua DeClerck
Just in case... check that all instances of &lt; and &gt; are changed into less-than and greater-than signs, respectively. I guess we aren't allowed to type those here.
Help us plant more trees
