We have chosen to utilize a Group Picker to populate a Custom Field used in our JIRA On Premises implementation.
As the JIRA admin, I get on average 5 - 6 requests per weeks to add new groups to JIRA.
What I am looking for is a way to enable a select set of power users to add new groups without giving them full JIRA Administration rights (for obvious reasons...)...
Does anyone have a solution (either via script, Add On, or other means) that you would be willing to share?
Thanks in advance!
We pull a subset of our Active Directory groups into Jira, and have a separate service that allows people to modify groups they own. It works ok.
Hi Matt -
Thanks for the quick reply. Are all of the groups in Active Directory? Or are the groups that our owned by others internal (which is the use case I'm addressing).
