HOW TO INTEGRATE THE POSTMAN TOOL WITH jira Zephyr VIA THE GITLAB PIPELINE
Why are you YELLING?
USE NEWMAN TO RUN YOUR POSTMAN COLLECTIONS, THEN USE THE ZEPHYR REST API TO SEND THE TEST RESULTS TO JIRA. YOU'LL NEED TO HAVE THE TEST CASE IDS IN JIRA AND CONFIGURE YOUR GITLAB CI/CD PIPELINE TO EXECUTE THE NEWMAN COMMANDS AND API CALLS TO UPDATE THE TESTS!
Hi Sunny , thank you for your update,
Is able to store the postman test report to jira Zephyr ?
Hi Sunny ,
I m using postman cli in GitLab pipeline
Is able to store the postman test report to jira Zephyr?
Yes
Good, then you won't need Newman.
script:
curl -u "$JIRA_USER:$JIRA_TOKEN" \
-X POST \
"http://$JIRA_URL" \
-H "Content-Type: multipart/form-data" \
-F "file=@results/results.xml" \
-F "projectkey=$PROJECT_KEY" \
-F "testCycle=$JIRA_CYCLE"
Please help me here and the pipeline run without any issues but not getting any update in the jira Zephyr. please provide the guide to complete.
Hi Sunny ,
thank you for updates and please provide the guide to complete.
