Handling multiple product lines
Saajan Kumar Sahu December 5, 2024
Hello All,
Is there any way to handle multiple product lines for a single bug from creation to closure?
Usecase:- Instead of creating multiple tickets we can have one single ticket for multiple product lines
John Funk
Hi Saajan,
Does these "product lines" already exist? Like are they projects? If not, then you can create Components for each product line and add them to the ticket.
Saajan Kumar Sahu December 6, 2024
no it doesnot exists
John Funk
Then I would just use the Components field.
sai chinamuthevi
You can Use components or labels also for Handling multiple product lines under one Bug
If i use labels its difficult to track when the bug is closed for only one product line in multiple
Carlos Garcia Navarro
Hi @Saajan Kumar Sahu ,
Would it work for your use case  to use different components for the product lines?
As a first option it would work
I'd use components.:-)
Saajan Kumar Sahu December 9, 2024
any lead on how to add components ?
snapshot of video would help.
Register now
