Hello Community is there a way to disable issue types in a scheme?
Orazio Pensabene June 19, 2018
Yogesh Mude
June 19, 2018
HI @Orazio Pensabene
Nope, if you don't want to use an issue type then you need to unassociated those issue type from Issue type screen scheme.
Scott Theus
June 19, 2018
Hi Orazio,
What kind of scheme are you referring to?
You can use an Issue Type scheme to select the issue types you will be using and assign the scheme to a project. here is some more information:
https://confluence.atlassian.com/adminjiracloud/issue-type-schemes-844500752.html
https://confluence.atlassian.com/adminjiracloud/adding-editing-and-deleting-an-issue-type-844500747.html
Does this help?
-Scott
Susan Hauth _Jira Queen_
You can edit  your issue type scheme and remove an issue type, but you may get prompted to move any existing issue to a new issue type.
Susan
Hi I was hoping not to delete just disable it so its not used, if I delete it will remove the issue type from past tickets... Any way to just disable?
Nic Brough -Adaptavist-
June 19, 2018
Same answer - if you remove an issue type from a project, you need to shift existing issues over to one that remains valid.
Register today
