Hello, I need help to automate the creation of dependabot tickets from GitHub to Jira using webhooks
Ajayi George
February 3, 2024
This were the steps I took but I still have an error creating an issue, apparently some fields where missing when I checked the audit log in Jira for  the payload message gotten from Gthub. What can I do about this please. Thank you.Screenshot (36).pngScreenshot (39).pngScreenshot (38).png
Kalyan Sattaluri
February 4, 2024
Hello @Ajayi George  You havent shared what the error is, so please share cause we cannot tell from your current screenshots what the issue could be.. It could be that Description is also a required field.
Can you try to create a task manually and see the fields you are required to fill?
Also, may sound obvious but can you log {{webhookData.security_advisory.summary}} instead of just {{webhookData}} to make sure you are capturing the correct value?
FREE
