Help to check the attachment in Jira?
kumar February 22, 2017
Dear Team,
I want to check the attachment in JIRA  using Attachment Event Listener. Please guide me how to do. I want to call the custom class to scan the document using Third Party.
Thanks in Advance
S.Indirakumar
Nic Brough -Adaptavist-
February 22, 2017
kumar March 4, 2017
Hi Nic Brough,
I followed your suggestion to create the listener. but when I run the project using atlas-run command, it throws the following error.Could you please advise me on this error.
Error: atlassian-plugin.xml contains a definition of component-import. This is not allowed when Atlassian-Plugin-Key is set
Thanks and Regards
S.indirakumar
March 5, 2017
I don't recognise that error, I suspect there's something wrong in your imports.
