Hi, I have the Jira cloud version.
I want to create a report or a widget to display some metrics in my project.
My project has the following custom Epic and Issue Types:
Ideation and PoC issue types are linked to Engagements (epics).
I want a report that shows me for each Engagement:
I have installed the Script Runner Add on in case that helps.
Many thanks in advance for your help.
Hello @Stu
Since you have script runner installed, you can easily implement these requirements.
Please read all the functions available in these 2 links and try them out based on your requirements.
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/enhanced-search.html
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/jql-aliases.html
Register now
