×I tried one the solution shared in this forum to update the fixversion, but having issues.
In the below code, user updating the issue with all unreleased version.
But, How can we updated the issue with a specific unreleased version? I would like to pass the version value through some variable. Really appreciate any help.
def versionManager = ComponentAccessor.getVersionManager()
def project = issue.getProjectObject()
def version = versionManager.getVersionsUnreleased(project.getId(), true)
if (version) {
issue.setFixVersions(version)
log.info("${issue.key} - fix version/s has been updated with ${version}")
else{
log.warn("Version does not available")
Where are you executing this?
Is it in a post function?
What this script does is look up ALL the unreleased versions in the project and adds them to the FixVersion field.
Probably the original post where you found it, they were managing the releases such that they only ever had 1 available to select and populate.
You must either hard code the name or id of the fix version you wish to apply.
You might also be able to add a keyword in the release description so that you can find it.
For example:
def versions = versionManager.getVersionsUnreleased(project.id, true)
.findAll{it.description.contains('automaticDefault')}
if (versions) {
issue.setFixVersions(versions)
log.info("${issue.key} - fix version/s has been updated with ${versions}")
else{
Thank you so much Peter, This is for a Post function. I did tried your code as below, But, encountered an issue.
Code:
def tVer = issue.getKey() // Issue key is in the fixversion description
.findAll{it.description.contains(tVer)}
if (versions){
else{
Error:
java.lang.NullPointerException: Cannot invoke method contains() on null object
at java_lang_String$contains.call(Unknown Source)
at Script10349$_run_closure1.doCall(Script10349.groovy:9)
at Script10349.run(Script10349.groovy:8)
Add some logging to figure out why it's failing:
def allUnreleasedVersions = versionManager.getVersionsUnreleased(project.id, true)
log.info "Found ${allUnreleasedVersions.size()} unreleased versions: $allUnreleasedVersions"
log.info "Searching for unreleased version with description containing $tVer"
def versions = allUnreleasedVersions.findAll {
log.info "Version $it.name has description $it.description"
def isMatch = it.description.contains(tVer)
log.info " Version is match: $isMatch"
isMatch
if (versions) {
} else {
log.warn("No versions matching $tVer were found")
Thank you so much Peter, really appreciate your help. I observed a strange behaviour. Not sure if it has to do anything with the number of unreleased versions in the project. I tried the below code with 3-4 unreleased versions Test project and it worked. When i tried on my actual project, it failed again. Sharing the log file for your review. Note: Removed some versions data due to sensitivity.
2023-03-01 15:01:05,315 INFO [runner.ScriptBindingsManager]: Found 497 unreleased versions: [2020-02 February, 2021-02 February, 2021-03 March, 2021-04 April, 2021-05 May, 2021-06 June,......all 497 releases including our version with matching description.
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Searching for unreleased version with description containing RSDEV-109342
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2020-02 February has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version is match: false
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-02 February has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-03 March has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-04 April has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-05 May has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-06 June has description
2023-03-01 15:01:05,316 INFO [runner.ScriptBindingsManager]: Version 2021-07 July has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version 2021-08 August has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version is match: false
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version 2021-09 September has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version 2021-10 October has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version 2021-11 November has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version 2021-12 December has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version ALaN_July has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version ALaN_August has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version ALaN_Sep has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version FWC has description
2023-03-01 15:01:05,317 INFO [runner.ScriptBindingsManager]: Version Address Architectural and Technical Needs for 2020 has description null
2023-03-01 15:01:05,319 ERROR [workflow.AbstractScriptWorkflowFunction]: Workflow script has failed on issue RSDEV-109342 for user 'Ameer@ameer.com'. View here: https://jiratest/secure/admin/workflows/ViewWorkflowTransition.jspa?workflowMode=live&workflowName=RI+Workflow&descriptorTab=postfunctions&workflowTransition=101&highlight=2
at Script10640$_run_closure1.doCall(Script10640.groovy:12)
at Script10640.run(Script10640.groovy:10)
Apologies for the inconvenience, Kindly ignore the multiple replies.
Dear Peter,
I tried your code with name as matching and it worked successfully. Please see the updated code below and let me know if anything should be corrected.
//log.info "Found ${allUnreleasedVersions.size()} unreleased versions: $allUnreleasedVersions"
// def isMatch = it.description.contains(tVer)
def isMatch = it.name.contains(tVer)
isMatch
if (versions) {
} else {
Glad you figured it out.
Hi @Ameer Syed
I suggest upgrading your ScriptRunner plugin to the latest release, i.e. 7.11.0 and looking at the new HAPI feature.
Below is a working example code to update the Fixed versions field with only an unreleased version using the HAPI API.
import com.adaptavist.hapi.jira.projects.Projects
def versions = Projects.getByKey('MOCK').versions
def released = versions.findAll { it.released }
def unreleased = versions - released
issue.setFixVersions([unreleased.first()])
Please note that the sample working code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
This example uses ScriptRunner's Custom Script Post-Function for the Done transition.
Below is a screenshot of the configuration for your reference:-
I hope this helps to solve your question. :-)
Thank you and Kind regards,
Ram
Imports are not required for HAPI classes
The versions can be obtained from the project the issue is located in
The following code finds all unreleased versions in the issue's project, it then appends them to the existing fix versions for the issue:
def unreleasedVersions = issue.projectObject.versions.findAll { version ->
!version.released
issue.set {
setFixVersions {
unreleasedVersions.each { version ->
add(version)
If you want to overwrite the existing fix versions on the issue entirely, you can use this code:
!version.released
issue.setFixVersions(unreleasedVersions)
Cheers!
Reece
The above code will only work in a post function, if you have another use case please let me know, and I can provide additional code examples :)
We are facing issues fix versions, sometimes old fix version is added to the ticket by accident.
It should not be possible to select a Fix Version which has Release date over 120 days in past.
example
On 22nd May 2024 it should not be possible to add fix Version which has release date 16th January 2024
