Help writing JQL
Chris Archey April 24, 2024
I'm looking for some help to write a JQL that will search all projects, where the result is all Epics that have a status other than done.
Thank you in advance.
Dave Rosenlund _Trundl_
Welcome to the community, @Chris Archey   👋
You may want to (should) be a lot more sophisticated than this for many reasons. For one thing, if you have a lot of Epics in Jira, this will be a taxing search.
But here's the simplest version I can think of:
issuetype=Epic AND statusCategory != Done
Be careful,
-dave
Kian Stack Mumo Systems
@Chris Archey
Welcome to the community! Hopefully this helps!
issuetype = Epic and status not in (Done)
If you want to learn more about Issue Searching and JQL, check out this documentation!
Ragavendran S
project in ("*")
AND issuetype = Epic
AND status != Done
vaibhav raverkar April 24, 2024
Try this buddy
type = Epic and Status not in (Done, Cancelled)
You can club it with other status as well, just take precaution if used two word status like To do
type = Epic and Status not in (Done, Cancelled, "To Do")
