Hide closed issues
Kelly September 9, 2019
I have more than fifty issues in the closed column.
How to hide them, please?
3 votes
Jack Brickey
You should add a sub-filter to your Kanban board, e.g.
resolved >= -2w OR resolved IS EMPTY
Component = KD AND resolved >= -2w OR resolved IS EMPTY
Thanks Jack
But when I add your solution in my filter, it removes all the issues from the other column
Do you have a solution?
Jack Brickey
Try this
resolution is EMPTY OR resolution is not EMPTY AND resolutiondate > -14d
Like Kelly likes this
Thank you very much for your help!
Even with this new filter it doesn't work. We see the other "component" appear, while I want to see only the "component = KD".
Jack Brickey
change your main project filter to include only KD components.
3 votes
Peter Ehardt December 3, 2019
Why are closed issues still showing up by default in the backlog view? What's the idea behind this?
and why is there no easy way of hiding them?
Oscar Quinteros
October 25, 2021
I vote for something like this:hide-by-status-2.png
Pete Singleton
September 9, 2019
As mentioned above, you can update the board query or subquery to hide closed issues.
Another option is to use the "Release" button on the top-right of the board, this will create a release and mark all the closed items as released, so they should no longer show.  You would need to to this periodically, say once a month, to stop the column from filling up again.
Sreenivasaraju P
September 9, 2019
Hi @Kelly ,
You can update the filter query of your board, such that close requests will not listed.
