Is it possible to hide system field such as "labels" but only on certain projects?
You can remove the Labels field from your screens. Some system fields cannot be removed, e.g. Summary obviously. The bottom line here is if it is listed on your screen then you can remove. Warning: if this is a shared screen scheme then changes will impact other projects that use the scheme. To avoid use a dedicated screen scheme.
Hi @Rob B
Field you say!! what you can do follow either of these to achieve it
