Hide the closed transition based on custom filed value without using add-on in jira cloud
Murugan Mittapalli
Hi All,
I have a custom called "What is the split tunnel status?" with values Enabled and Disabled, when i select Disabled option i would like to hide the closed transition, remember without using add-on.
Thank you.
Murugan Mittapalli
Found the solution using the workflow Value Field Condition.
Thank you.
