Is it possible to hide values dynamically from the "Components" select list based on some criteria?
I would imagine by using a scriptrunner behaviour.
If anyone has an example would be much appreciated :)
Hi there, you can try some something like below using the Behaviour:
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours behaviours
def componentCF = getFieldById("components")
log.error componentCF.getValue()
def project = underlyingIssue.projectId
// Get all available components
def components = ComponentAccessor.getProjectComponentManager().findAllForProject(project)
// Define your restricted components
def retrictedComponents = ['a','b'] // a and b is my component name
// Filter the components
def allowedComponents = components.findAll {
it.name in retrictedComponents
componentCF.setFieldOptions(allowedComponents)
I hope the above helps!
Hello
Thanks for your answer.
I would like to hide some values in the components, so i do that
def retrictedComponents = ["1/ GDA 2/ Création de compte",'1/ GDA 2/ Habilitation de compte'] // a and b is my component name
But nothing is done.
Can you please help me.
Fayçal
Hi Fayçal,
To exclude the components, you will need to change the logic from this:
to this:
!it.name in retrictedComponents
Else, it will include those in the retrictedComponents instead.
Hello @Benz Kek _Adaptavist_ ,
I do this script in my Behaviour :
log.warn("componentCF: "+ componentCF)
log.warn("project: "+ project)
log.warn("components: "+ components)
def restrictedComponents = ['1/ GDA 2/ Création de compte','1/ GDA 2/ Habilitation de compte'] // a and b is my component name
//def restrictedComponents = ['a','b'] // a and b is my component name
log.warn("restrictedComponents: "+ restrictedComponents)
!it.id in restrictedComponents
log.warn("allowedComponents: "+ allowedComponents)
But in my components Field, i have this :
I excluded those two values {'1/ GDA 2/ Création de compte','1/ GDA 2/ Habilitation de compte'} but i still see them in the list of components.
can you please help.
Fayçal.
Not sure why you changed this from your previous post, but you are filtering using it.id instead of it.name that I specifically quoted them in my previous reply.
The correct one should be:
!it.name in restrictedComponents
I am trying that script without success. Where should be added? initialiser?. I don't know why is not working properly. Basically I would like to hide Component Q_NC_mayor in this below example but I see when creating an issue.
def retrictedComponents = ['Q_NC_mayor']
In your case some Components are hidden by default but I'm not sure how to show different Components based on custom field value.
Hey @Javier,
It depends on how you want it to behave.
For example
In your case, you would need more conditions.
For starters, you can try these where I change the component list based on the Priority field value:
def priorityCF = getFieldById("priority")
// Let's say I want to restrict components based on Priority value
def priorityName = priorityCF.getValue().name
if (priorityName == "Highest") {
} else if (priorityName == "Low") {
retrictedComponents = ['c','d'] // c and d is my component name
This code needs to be added under the Priority field -> Server-side script.
Hi all,
Thank you for this useful code. I have been able to use this successfully as an initialiser upon issue edit, but it fails upon issue create "Cannot get property 'projectId' on null object"
This makes sense, because as there is no Project yet set on an issue that is yet to be created.
I have tried many variations of trying to get the project ID through the issuecontext, but all have failed (examples:
Hypothetically, I don't really need to pull in the project components and could just hard code the list I want to show without caring what exists in the project, but I'm not sure if Jira will let me do that.
For anyone looking to do something similar, here is how I got it to work:
What is the criteria in details?
It's a code, it needs to be detailed to make it work well.
By the way you might find this page useful: https://scriptrunner.adaptavist.com/6.16.0/jira/recipes/behaviours.html
This contains lots of examples including setting component values.
