Sign up Log in
How Can Hide Boards from Deleted Projects?
Serge Creator January 13, 2024
I've deleted some projects, but boards remain visible, or maybe I've created boards and deleted them, but they are still visible in the menu. How can I hide them or delete them?
Please take at screenshots.
Here is the error when I'm clicking on it
6 votes
David Bakkers
January 14, 2024
Hello @Serge Creator
Are you 100% sure the Project has been completely deleted? Are you sure it isn't just sitting in the trash awaiting permanent deletion?
Serge Creator January 14, 2024
Yeah maybe, how can I check it?
Boom! You were right. I've deleted it in settings, and it disappeared now. Thank you for your help @David Bakkers
Murat Seven
January 14, 2024
Hi @Serge Creator and thank you for your question.
If you want to delete the board from the project.
Go to Your Work -> Boards -> View all boards ->  Click in the "..." icon -> Delete your board.
If the answer helps, Please accept the answer.
Best,
Murat Seven
Hey @Murat Seven please take a look. I don't have any boards besides these two
The 3rd one is shown below not sure why
FREE
