How I can create custom field same like issuetype
shahjad ahemad
Is there any way possible we can create new field in jira which is same like issue type which will give you the id of issue key.
Alex Koxaras _Relational_
March 24, 2023
Hi @shahjad ahemad
You can create a text field, which you will copy the issue key. But in general you can't create an "issue type" type field, and an "issue key" type of field.
Nic Brough -Adaptavist-
March 24, 2023
No, both the issue type and issue key are unique (and structural) system fields.
You could create text or select lists that hold data with the same names as your issues and keys, but they won't take over from the issue type or key, they'll just be data points on an issue.
