How I can create filters in Jira software trial?
Praveen Gupta
I found option Manage Filters.
Some filters are showing here already related to created Kanban Board. From where these filters created.
How I create a new filter. Not found Create Filter option here.
Jack Brickey
January 27, 2018
You can create and save filters from the view issues screen. You can do this in Basic mode or Advanced using JQL (Jira Query Language). Here is an article that should help.
Praveen Gupta
Some filters are showing already under Manage Filters option. Want to delete those but can't. Not able to find Delete filter option on the page.
I have went through the link page which you have provided, as per that page:
  1. Click the My tab on the 'Filters' page.
  2. Locate the filter you wish to delete, click more () > Delete.
But I didn't found My tab on the 'Filters' page.
Nic Brough -Adaptavist-
January 28, 2018
There are two default filters on that menu that are useful for everyone (in testing, Atlassian found that if they were not there, everyone created their own which were identical).  They are built in and cannot be removed.
Jack Brickey
January 28, 2018
@Praveen Gupta, were you able to create new filters now?
Praveen Gupta
Not exactly Jack.
I just opened the already created filter & after some change perform "Save as" option. And give a new name to the filter.
Didn't found "Create Filter" option.
Jack Brickey
January 29, 2018
There isn’t a “create filter” button. The method you used is certainly fine. The other way is to simply perform a search for issues and using either Basic or Advanced (JQL) construct a search and the click save. Both achieve the same goal and often starting with an existing filter save time if it closely resembles then end goal.
Praveen Gupta
Thanks Jack
