Hello People
i am trying to find if there is a way to create Confluence page, while creating jira issue.
For example, i click on new issue, and there is Field or button to create confluence page(Which is neccessery in my case) . after creation this issue and confluence page should be linked..
any help?
thanks in advance
Hello @ddch.peradze
I apologize for the very late answer, but since I'm not sure you got the help you needed, I'll do my best to help with an up-to-date solution. So, if you don't mind using an add-on, Elements Publish lets you do exactly what you are asking.
Full disclosure: I'm the Head of Product at Elements, which is developing this app.
With our app you can create Confluence pages from Jira issues, either manually (by clicking a button in the issue) or automatically (with a post-function or Automation, for example when your issue is created).
Elements Publish has many more features than any native solution. Indeed, you can :
The app is free for 30 days, (and stays free if your instance is under 10 users), so feel free to give it a try, and don't hesitate to tell reach our Support if you have any question.
Julien
I think you could "borrow" the code from https://library.adaptavist.com/entity/create-a-confluence-page-for-each-subtask-of-an-issue (you'll need to click on the "Cloud" tab to get code for Cloud)
Thank you nic it worked i used code for cloud!
One remaining problem , i want code that will automatically link newly created page to this issue, with postfunction and scriptrunner, any suggestions with this too?
I Am using Script below with ScriptRunner but it has errors, on importing files.
any suggestions?
Learn more
