How add a project of bitbucket to Jira
williamespindola July 21, 2015
I made this setting https://confluence.atlassian.com/display/JIRACLOUD/Linking+a+Bitbucket+or+GitHub+repository+with+JIRA
In DVCS accounts I can see the new project created on Bitbucket but how use is on JIRA?
williamespindola July 23, 2015
My DVCS connection is ready. I can see my project on listed on add-on -> DVCS accounts.
For example I create an app call stack on bitbucket and other in JIRA call stack too. How can I make this tow projects work together?
Today if I create a Branch via JIRA it open on bitbucket but I can't see this on issue at JIRA.
Marlon Grawer July 23, 2015
Hello William,
First, we need to understand one important thing as a principle: The internal JIRA for Bitbucket and JIRA Cloud are different applications. I believe you can connect these applications via DVCS, and still work in a project you've created in the internal Bitbucket JIRA using the Cloud JIRA. However the progress on your project will not be synchronized back to the Bitbucket JIRA. So I'd recommend you choose what JIRA you want to use before you start working in your project.
Hope this explanation helps you out.
Marlon
Get Certified! ✍️
