×Hello,
I'd like to set the resolution codes in automation according to the ticket types.
I use one issue type: Support
I added another field which is called Sub-type. Sub-type values:
Support
Bug
Feature Request
I cannot seem to automate the 'Resolution' field in Automation.
This field is not available in the automated action "Edit Issue"
How can I automate and set the 'Resolution' field in Automation?
If you are referencing to Automation for Jira, then I'm able to set the resolution in JSD.
See example below:
Can you explain how exactly you are setting up your rule?
Thank you, Gil.
I don't use the Automation for Jira plugin or any other plugin.
I use the available automation that is the Jira Service Desk Project
Here is the exact scenario ( I am attaching a screenshot of the Automation for clarification):
A customer support ticket (CS Ticket) is the one to communicate with the client.
In case of a bug, the CS ticket is linked to a BUG Ticket.
The Automation:
The Status of the CS ticket is changing according to the status transition go the BUG ticket.
The last part of the Automation I'm trying to implement:
When the status of the BUG ticket is set to 'Complete.'
Set the Status of the CS ticket to 'Done' and Set the Resolution code to "Code Fix."
While I can Set the Status of the CS ticket to 'Done,' I cannot see a way to set the resolution code to "Code Fix."
Thank you again, Gil, for your time and thoughtful advice.
see my above answer.
This is not possible, unfortunately.
@Gil Can you explain how you got the "No Response" option (which I am guessing is a "blank" response) to show up? When using Automation for Jira, I can only change the Resolution to one of the pre-existing Resolutions (Done, Won't Do, etc.), not set it to blank.
Cheers!
If you have Admin rights in Jira, you can manually add more Resolution types.
I've added "No Response" and I use it once there's no activity after 10 business days.
Ah, okay. I thought that was a system-defined entry that would actually clear the resolution out. I don't want reopened issues to have that strikethrough!
I was able to get what I wanted via a POST function in the workflow. But it's no fun implementing that POST function in potential hundreds of workflow steps across dozens of workflows. A global automation solution would be much easier.
Cheers
For those who are interested in a tutorial about updating the resolution field with jira automation, check this guide: https://www.youtube.com/watch?v=S2ary5YG-7w&t=3s
I can't tell if you are referencing Automation for Jira plugin by Automation or something else.
If you mean to use the automation for JIRA the following may help. Otherwise I recommend opening a support ticket with the plugin developer. https://codebarrel.atlassian.net/servicedesk/customer/portal/1
Here is a link for creating basic rules editing custom fields:
Additionally, if you just want to set a specific resolution for the subtasks you can simply use the post function to update the resolution field in each of the transitions for each of the subtasks. Below is a link which can help with this strategy.
Thank you, David.
The Automation:
Thank you again, David, for your time and thoughtful advice
Hi @Nir Malchy
Now that I understand your scenario, I can tell you that this is a limitation of JSD.
For some reason, Atlassian didn't include the Resolution field to be set by JSD Automation.
This is a serious limitation which forces people to pay extra for Add-ons to do this job for them.
Here's is the JSD cloud issue where you can vote and comment to push this in pipeline for fixing JSD:
Hi Agin Gil! We ended up getting the Automation plug-in as a part of Jira. I wanted to seek some more advice from you.
I'd like to create an Auto response that goes out to the report when a ticket is created:
After hours (I have an SLA which is weekdays 7:00 AM to 5:00 PM calendar) - so basically anything that comes between 5:00 PM and 7:00 AM.
Holidays - days that are designed as holidays in the same calendar.
Any guidance will be much appreciated. Thank you!
Hi Nir,
you need to use:
1. Trigger: Issue created
2. JQL Condition: created >= startOfDay(-7h) AND created <= startOfDay(17h)
3. Action: Comment on issue - Add your comment to the customer.
4. Click on the drop-down of More Options under the Comment on Issue action and tick the box 'Share with customer'.
Please validate the JQL that filters the correct issues you want.
Thank you!
So I tested that and it activated in the 'on hours'.
I wonder if I should be more like an 'OR' since it is "Before 7:00 AM OR After 5:00 PM".
So I am testing "created <= startOfDay(+7h) OR created >= startOfDay(+17h)"
Thank you @Gil
Thak you @Zack Foster and @David Sweeney
Now, that I have the Automation for Jira as a part of the service desk, how would you create an auto-response that is for days that are designated as 'Holidays' - days that are designed as holidays in the same calendar?
How does this work with off-hours? Meaning, what is someone write in at 6:00 PM, which is always an 'off-hour', on a day that is designated as a holiday in the calendar?
Thank you again for all your help and support.
you can try to use the withincalendarhours() function. if you search for all issues which are NOT withincalendarhours() that should yield all tickets that are outside of calendar hours.
I haven't tried it but I believe that anything that falls over a weekend or a holiday is essentially NOT withincalendarhours()
I think this will cover off-hours as well.
Use JQL with this function and see if it shows you what you expect to find.
You might also try to use an OR function to combine created >= startOfDay(-7h) AND created <= startOfDay(17h) with withincalendarhours() to cover all bases.
But I suspect withincalendarhours() is sufficient to cover all bases.
Then use my above automation example to build upon this function.
