I'm using JIRA service desk, cloud.
I notice a few small automation features, but nothing that would allow me to automatically close issues based on data like time spent, issue type, etc.
Is this possible?
Hi Tony,
Here's how I achieved automation for closing an issue after timeout with JIRA Service Desk:
Does it sound like that approach would work in your scenario?
Thanks Tony, have a great day,
Nick Muldoon
Co-CEO, Easy Agile
Easy Agile, creators of Agile User Story Maps for Jira, Agile Roadmaps for Jira, Personas for Jira, and Scaled Agile Programs for Jira
I just wrangled this out with a customer today, and we came to the same solution! So funny to see it right now on a question I'm watching.
Hi Tony,
Unfortunately it is not possible in a Cloud instance.
Henrique Freitas
If you can define a JQL statement that identifies your conditions for closure, then, using JIRA Command Line Interface (CLI), you can use something like the following in your favorite job scheduler:
jira --action runFromIssueList --jql "status = resolved AND resolutiondate < -1w" --common "--action transitionIssue --issue @issue@ --transition \"Close Issue\" "
The only method of doing this sort of automation would be externally. JIRA Cloud instances can enable Remote API access, so you can write a script in just about any scripting language (such as Python..) that can perform the following –
type=Request AND updated(-30d)
"The point is you can do it but you have to maintain the 'service' yourself.
