How can I change WBS Gantt-chart settings in transition to make dates no editable?
Dmitry Brechalov March 9, 2017
There is a status BlueApproved in a workflow, which means that all dates are already approved and may not be changed anymore.
How can I prohibit changing the dates in WBS Gantt-Chart plugin when the issue passes to this status?
I.e. by default Start Date and End Date are editable here, but after the issue came to BlueApproved status, they should be not editable.
yuki
March 9, 2017
Hi, Mr Dmitry Brechalov,
Thank you for your question about WBS Gantt-Chart.
WBS Gantt-Chart does not support the function you suggest.
We would like to receive your suggestion as a request and discuss at new feature meeting internally later.
Your great feedback would be much appreciated.
Warm regards,
Yuki Suzuyama,
Ricksoft,
