How can I change a fix version on an issue already started?
Guðbjörg Eva Halldórsdóttir
March 9, 2016
If I remember it correctly we had the option of changing the fix version of an issue already in progress. Now I can't seem to be able to do that.
Can anyone advice?
Thank you in advance,
Gudbjorg
Cristina_Abunei
March 9, 2016
Hello, if you have the fixVersion on your edit screen you should be able to remove the current version and add the new one.
Learn more
