How can I configure my Sprint Boot application to use Jira as an OAuth authentication server?
What do I have to specify for the `resource-details-service` element? (especially key, secret, ...)
Is there a sample implementation from Atlassian anywhere?
<?xml version="1.0" encoding="UTF-8"?> <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd"> <modelVersion>4.0.0</modelVersion> <parent> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-parent</artifactId> <version>2.7.2</version> <relativePath/> </parent> <groupId>com.example</groupId> <artifactId>demo</artifactId> <version>0.0.1-SNAPSHOT</version> <name>demo</name> <description>Demo project for Spring Boot</description> <properties> <java.version>1.8</java.version> </properties> <build> <plugins> <plugin> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-maven-plugin</artifactId> </plugin> <plugin> <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-install-plugin</artifactId> <version>2.5.1</version> <executions> <execution> <id>id.install-file</id> <phase>clean</phase> <goals> <goal>install-file</goal> </goals> <configuration> <file>C:\Program Files\CData[product_name] ####\lib\cdata.jdbc.jira.jar</file> <groupId>org.cdata.connectors</groupId> <artifactId>cdata-jira-connector</artifactId> <version>23</version> <packaging>jar</packaging> </configuration> </execution> </executions> </plugin> </plugins> </build> <dependencies> <dependency> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-web</artifactId> </dependency> <dependency> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-jdbc</artifactId> <version>2.7.0</version> </dependency> <dependency> <groupId>org.cdata.connectors</groupId> <artifactId>cdata-jira-connector</artifactId> <version>23</version> </dependency> <dependency> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-test</artifactId> <scope>test</scope> </dependency> </dependencies> <distributionManagement> <repository> <uniqueVersion>false</uniqueVersion> <id>test</id> <name>My Repository</name> <url>scp://repo/maven2</url> <layout>default</layout> </repository> </distributionManagement> </project>
Hi Dirk,
I would recommend checking out the documentation on OAuth 2.0 - JWT Bearer token authorization grant type and OAuth for REST APIs
These explain an overview of how you can configuring a plugin/application to use Oauth with Jira.
Sorry if this is not exactly what you are looking for. If you are in search of more detailed instructions for your use case, I would actually recommend posting this kind of question to our Developer Community instead, https://community.developer.atlassian.com/
Read the story
