How can I create a Jira issue using Slack?
r.engel March 29, 2019
I do receive notifications in Slack.
Now I also want to create issues directly from Slack. How can I do that?
Navin_Sridharan May 25, 2019
Is this possible for Jira Data center using Jira Server for Slack app ?
Navin_Sridharan May 27, 2019
Hello all,
Could you please advise on this. Thanks!!
https://marketplace.atlassian.com/apps/1220099/jira-server-for-slack-official?hosting=server&tab=overview
This is the plugin that I have been using in Jira Data Center.
Navin
Trevor Thompson
April 19, 2019
Hey @r.engel good news - We just shipped this functionality!
Check out more info here: https://medium.com/@trevor_atx/3-new-ways-to-create-jira-issues-in-slack-3c61ed9a4247
Trevor Thompson
Product Manager, Product Integration
shetty
April 19, 2019 edited
this is amazing, tried and it worked
Like • Trevor Thompson likes this
Azfar Masut
May 6, 2020
@Trevor Thompson what about for JIRA server/dc? seems like this is only for clouds?
Hi Ramesh,
also with Jira Cloud for Slack I do not find the way to create issues.
If I use Jira Cloud help, it shows me this:
/jira create :<summary> :<parameter> [value] - Create Jira issue
But it can't get it working. Can you help?
Rafael
shetty
March 29, 2019
you can't create issue directly from slack refer 2nd link for plugins available for the same
shetty
May 27, 2019
Hey, now it's working you can create jira issue from slack
Type /jira create in jira cloud under apps
you will get options to create issue
Navin_Sridharan June 2, 2019
Hi @shetty ,
Is the functionality of creating jira issues from Slack possible for Jira server/Data Center as well?
shetty
June 6, 2019
Hey @Navin_Sridharan
open jira cloud under apps
and type /jira if it will prompt like in the image if you have option create then you can
shetty
March 29, 2019 edited
