How can I create a button with a link embedded in it when creating request types for a project??
Adebayo Banjo
Hi community,
I have a service management project and in one of the request, I will like  to add a google form link to a request type field called "Google Doc", so when the user clicks the field, it opens the link embedded in the form. Please how can I do it?
Presently I just put the link under a field description called "Google Doc" and that doesnt look clean, the link should not be visible, just "Google Doc"
I have attached a picture for reference of whats its like nowScreenshot (179).png
3 votes
Mark Segall
November 3, 2022
Hi @Adebayo Banjo In your field description, you can use markdown.  It should be formatted like this:
[example|https://example.com]
Adebayo Banjo
November 3, 2022 edited
Hello @Mark Segall ,
Thanks for your response. But I am a little lost, do you mean I should add that format when I am creating from the create custom field section? Also what will the field type be? ThankScreenshot (182).png
Mark Segall
November 3, 2022
Hi @Adebayo Banjo - I'm talking about where you added the link to Google in your request type settings for the project.
Adebayo Banjo
Hi @Mark Segall ,
Thanks alot, you saved me a lot of time.
Like • Mark Segall likes this
Christine Nguyen March 16, 2024
Hi
@Mark Segall or @Adebayo Banjo
This is something I am looking for as a solution to intake project.  I am not quite follow the conversion exchange here, can you help me understand?
so I have a google from created and a JSM project with a request type “project request “.  How do I married these two together so that when a customer goes to JSM customer portal and raise a request for project request, he can complete the google form?
thanks
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
