×I would like to create several sections
Sprint.
Backlog
Ready for Grooming
Pre-grooming
Draft or General Tickets
How can I do that? Any tips are appreciated.
Hi @José Namén
It's not possible to have "multiple backlogs' natively.
But there are a few alternatives - which would work best will depend on your need!
In Company-managed Projects, you could:
Similar options exist if you're using a Team-managed Project:
Let us know if any of these work for you!
Ste
Hi Jose,
At my company, on of the main reasons we shifted to scrum from Kanban was the ability to use Sprints to categorize our backlog items. Our sprint list looks like the following
Some teams are able to plan ahead an have the next sprint or two also planned and in the backlog.
Hope this helps!
-Aaron
Hi @Aaron Brady ,
We have a specific sprint naming convention. I assume that if I were to create a "sprint" called "Groomed Backlog," that would potentially adversely affect my company's reporting, correct?
Hi @José Namén and welcome to the community!
You can't have different sections on the backlog BUT as a workaround you can create a custom field with all these backlog statuses. Then, and when you assign each of your issue to a backlog status, have this field appear on your backlog via the board settings: Something like this:
Welcome to the community
You can't do this unless you create your own addon. You could try to play with the card color to display the same color for backlog item, pre-grooming etc
