How can I deactivate a user using curl
Guy Matz
Hello!  I'm using the following command to try to deactivate a user, but it's not working:
curl -k -v -u admin:password -H "X-Requested-With: XMLHttpRequest" -H "Content-Type: application/json"  -X POST https://jira-server.atlassian.net/admin/rest/um/1/user/deativate?username=user2delete
* About to connect() to jira-server.atlassian.net port 443 (#0)
*   Trying 104.192.140.242... connected
* Connected to jira-server.atlassian.net (104.192.140.242) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* warning: ignoring value of ssl.verifyhost
* skipping SSL peer certificate verification
* SSL connection using TLS_RSA_WITH_AES_128_CBC_SHA
* Server certificate:
*       subject: CN=*.atlassian.net,O="Atlassian Network Services, Inc.",L=San Francisco,ST=California,C=US
*       start date: Sep 09 00:00:00 2014 GMT
*       expire date: Nov 15 12:00:00 2017 GMT
*       common name: *.atlassian.net
*       issuer: CN=DigiCert SHA2 High Assurance Server CA,OU=www.digicert.com,O=DigiCert Inc,C=US
* Server auth using Basic with user 'admin'
> POST /admin/rest/um/1/user/deativate?username=user2delete HTTP/1.1
> Authorization: Basic YzlnbWF0hHdoLmWxjb21lMTIz
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.16.2.3 Basic ECC zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: jira-server.atlassian.net
> Accept: */*
< HTTP/1.1 404 Not Found
< Server: nginx
< Date: Thu, 07 Apr 2016 18:41:50 GMT
< Content-Length: 0
< Connection: keep-alive
< Set-Cookie: studio.crowd.tokenkey=hSHRvShyG6fi6uFOya5tkQ00; Domain=jira-server.atlassian.net; Path=/; Secure; HttpOnly
< X-Application-Context: application:prod:8080
* Connection #0 to host jira-server.atlassian.net left intact
* Closing connection #0
3 votes
Guy Matz
WAIT!!!  That was almost it!!  This actually works.  With Cloud, anyway . . .
curl  -u $USERNAME:$PASSWORD --header "X-Atlassian-Token: no-check" -H "X-Requested-With: XMLHttpRequest" -H "Content-Type: application/json"  -X POST https://${INSTANCE}/admin/rest/um/1/user/deactivate?username=user2deactivate
Nabil Sayegh
January 9, 2017
Doesn't work with 5.8.18. What Confluence version are you using?
Guy Matz
This is for Jira, not confluence
Kay A. Schink
June 13, 2017
Seems like it is not working anymore. I guess since atlassian forced users to chnage to atlassian account.
Anyway, I am getting "User failed to authenticate". Neither old username nor full email address works.
If anybody knows a workaround, would be awesome.
Guy Matz
It's still working for me.  Can you post the output using "curl -v -s"?  Don't forget to remove the password and the "Authorization" line from the debug output
Guy Matz
July 28, 2017 edited
I guess Atlassian finally got around to updating my cloud instance.  The way to do this now is by using cookies to authenticate.  So, first:
curl -s -c cookie_jar.txt -H "Content-Type: application/json" --data '{"username":"admin_user@domain.com", "password":"PASSWORD"}' -X POST https://cloud_server.atlassian.net/rest/auth/1/session
Then
curl -s --cookie cookie_jar.txt  -H "Content-Type: application/json"  -X POST https://cloud_server.atlassian.net/admin/rest/um/1/user/deactivate?username=user_to_deactivate
Like • Parker Van Dyk likes this
Trevan H September 14, 2017
Worked for me - Thanks! (Cloud)
Ashley Watson April 10, 2018 edited
We have just switched over to domain validated domain (using Atlassian Identity Manager).
Identity Manager allows for generating an access token...
so I generate an access token from my site owner logon;
https://id.atlassian.com/login
and then I try;
curl -v -H "Content-Type: application/json" -X POST --user siteadmin@site.com:tokenvalue https://xyz.atlassian.net/admin/rest/um/1/user/decativate?username=ruserabc
and I get a "User failed to authenticate" message.
Has anyone got this to work with Atlassian Identity Manager and access tokens (as we are using SAML)?
Console Australia Pty Ltd
January 30, 2018
If you want to delete for any reason you can follow pretty much the same info above and just change the url and the method, see below;
curl -s --cookie cookie_jar.txt  -H "Content-Type: application/json"  -X DELETE https://cloud_server.atlassian.net/admin/rest/um/1/user?username=user_to_delete
Guy Matz April 15, 2016
I'm an idiot.  The curl command above works.  I was using the wrong password
Ignacio Pulgar
April 17, 2016
Could you possibly accept your answer?
Aleks Yenin (Polontech)
April 8, 2016
Deactivating a user at his time is only possible Via the UI
The ability to Deactivate users via API is being tracked in this feature request:
Guy Matz
Thanks!  But it seems like it should be possible to mimic the UI with curl, even if it's not as simple as hitting a REST endpoint, no?
