×Hi JIRA Support:
I've run into an issue where orphaned sprints from deleted boards still show up in my project. Is there a way to delete orphaned sprints after I've deleted the boards? The issue I'm having is the same as what is posted under the first response (copied support text) from this thread:
https://answers.atlassian.com/questions/295346
Thanks in advance.
I'm not sure if it helps, but I have an alternate that I tried. Assuming your situation was like mine, then this may help. This is also for anyone else who stumbles upon this.
This ticket outlines a solution in the comments - I followed the advice here and it worked
https://jira.atlassian.com/browse/GHS-11263
you sir are a hero, thank you!!!
Sadly this is not an option in our case where we have literally hundreds (in fact, there's no way of determining how many either) of orphaned sprints due to a mass clear out of old projects.
We need a way to mass-delete empty/orphaned sprints - otherwise they show up in the Create/Edit issue Sprint dropdown.
Beautiful!! Thank you sir!
You can delete the sprint in the database.
The above queries are written in MySQL syntax. You may need to tweak the syntax if you are running another database platform.
