How can I disable automatic AI summary of work items?
Rick Westbrock
July 18, 2025
Recently I when I view work items I have been presented with an AI summary of the work item automatically as shown below (I find it amusing that it refers to the work item as a "ticket"):
I find this quite annoying as it pushes the comments down the page and I have to click the X button to close the AI overview. I suppose my annoyance stems from the fact that I am the assignee so I'm already intimately aware of all details in the work item. I don't see this overview every time I view a work item but sometimes for a particular work item which I might view six times in one day I get this overview more than once.
While this doesn't "break" anything in my workflow it is very annoying and I can't find a setting anywhere to disable this feature. I also don't understand why the feature wasn't implemented as a button for the user to click when they want to see the overview as that would reduce compute usage on the Atlassian side.
Does anyone have any idea how I can disable this for myself? I am a site admin so in theory I could disable it globally but I'm not sure that I can get approval to do that.
2 accepted
Rick Westbrock
July 29, 2025
I did end up raising a case with Support since this was driving me nuts. They pointed out that if you expand the full AI summary there's a link to Turn automatic summaries off as shown in the image below. I don't know how I ended up with automatic summaries turned on as I don't recall clicking that option at any point but it's still odd that not every work item was displaying the summary automatically.
Tomislav Tobijas
Interesting 🤔
As Atlassian promotes AI, it probably gets enabled/turned on quite easily (without you even knowing that)
In any case, thanks for sharing the info @Rick Westbrock !
Like • Jörn Merkel likes this
Tomislav Tobijas
Hi @Rick Westbrock ,
Interesting behavior indeed. I always have to click on the summarize comments button for this part to pop up.
Now, I would suggest trying to 'decipher' cases when it represents itself even without having to click on the button 👀
Maybe you could even try to reach out to Support to see if they can make any additional background checks.
Now, as for disabling specific AI features, this isn't possible (either on global or personal level), but there's a feature request for it: ROVO-107: Enhanced Granular Control Over AI Features (it's all dropped under 'ROVO' but this applies to AI features as well)
Tobi
Rick Westbrock
July 21, 2025
Thank you, I had a feeling that I would end up with a Support case for this since it felt like a really odd situation. I have not been able to detect any pattern to when the summary is displayed. The only long shot hypothesis I have is that in Jira and Confluence I keep seeing in-app notifications which I already marked as read which feels like a cookie issue (as does the fact that my browser keeps "forgetting" that I'm logged into applications) so maybe AI "forgets" that I've already seen the work item summary.
I had worked with my desktop support team on the cookie issue a while back and their only solution was to switch from Chrome to Edge which helped for about four days then I started seeing the same behavior again.
Thanks for the pointer to the JAC issue.
Like • # people like this
